LTC2499
Someone can help me with a Labview VI example to run ARD-LTC2499 (16 ch/24 bits ADC) connected to an Arduino Uno.
(1,838 Views)
Hi Haygas,
you should ask this in an Arduino board: I guess you will find examples for this circuit over there.
Then you should write an Arduino sketch to handle the communication with this IC.
The problem then reduces to the usual communication between Arduino and PC/LabVIEW over the virtual COM port of the Arduino…
(1,786 Views)
Thanks, I will follow your advice...
(1,768 Views)
