LV 2009 bug - Dynamic dispatch selection dialog does not bring the VI to the front if it's already open
In LV 2009, if you double click an implementation in the dynamic dispatch selection dialog and that VI is already open, it will not be brought to the front. This worked correctly in earlier versions.
Have a look at the attached project for an example.
___________________
Try to take over the world!
(3,602 Views)
I wonder if that could be the results of a bug that skipped the dialog and selected the version for you.
Ben
(3,585 Views)
I assume you mean "the result of fixing a bug", although I'm not personally aware of such a bug.
In any case, 2009 doesn't skip the dialog. It just fails to bring the FP to the front if the VI is already open.
___________________
(3,571 Views)
Yes. If I double-clicked a dynamic dipatch icon in a diagram, rahter than opening the dialog screen that let me choose the flavor, it would skip the dialog. Work-around was right-click on the diagram instance and select open.
Ben
(3,566 Views)
Accepted by topic author tst
Please try dropping the attached VI on top of Program Files\National Instruments\LabVIEW XXXX\resource\Framework\Providers\LVClassLibrary\ChooseImplementation\CLSUIP_OpenImplementations.vi and let me know if it works for you.
(3,500 Views)
This solves the problem, thanks.
___________________
(3,483 Views)
