03-22-2011 07:19 AM
When I drop a constructor node onto the block diagram, LV freezes for around a minute. It seems to work ok after that.
However, when I run the program, LV again freezes when it gets to the constructor in the code. Again, for around a minute.
I was hoping SP1 would fix this but nope. So, as a result, I'm forced to use an external exe written in C# do do what I need it to do.
Is there a workaround with this issue?
03-23-2011 01:05 PM
Wayne,
Is it when you use any .net structures or only the one in your application? A good way to check this is to go through the example finder to our .net examples and try running a few of those.
what version of .net are you using? have you ever successfully used .net items in the past on this machine?
Kyle Mozdzyn
Applications Engineering
