LV 2010 dark background
I have some example vi's with a darker background then the standard background color of LV 2010 vi's. How to get this background so dark?
(2,675 Views)
you can modify the Vi background color using the tools palette or Tools=> Options=>Environement=>Colors
Rodéric L
Certified LabVIEW Architect
(2,668 Views)
Hi JoVMo,
To change the background of a VI you use the Set Color Tool.  If you navigate to "View >> Tools Palette" and select the color (both default grey), you can then click on the background and its color will change.
Peter D
Peter D
(2,665 Views)
