LV 2021 stability issues
I have found several potential triggers that may make the LabVIEW IDE unstable and cause indeterministic crashes, especially in combination:
  • Subpanels
  • .NET Callbacks
  • Remote Debugging
Also note that there are also known deterministic sources for IDE crashes.
I'm experiencing 1-2 crash episodes per week. About once per day I receive a "crash recovery" on startup even when LabVIEW exited properly.
Can you reliably reproduce the crash and show us a screencast or give a step-by-step instruction?
Message 11 of 13
(459 Views)
The last versions i've had few crashes. A month ago i managed to fill the memory and then everything was borked until i restarted, but apart from that the biggest issues i've had is too aggressive Anti virus preventing me from installing LV or SP1 in general.
I'd start by running a LV repair.
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 13
(447 Views)
Running out out of RAM during the execution of a .vi can crash the .vi or even the whole LabView IDE.
Message 13 of 13
(440 Views)
