LV 8.0.1 chrash when I try to delete a flat sequence frame with contens.
Dear LabVIEW users.
I found another bug in LabVIEW 8.0.1.
When I try to remove the first frame of a flat sequense that is filled with controls
LV crashes. After dragging the code and controls out of the first frame (its empty
now) I can delete this frame without a crash.
With kind regards
Martin Kunze
KDI Digital Instrumentation.com
e-mail: martin.kunze@digital-instrumentation.com
Tel: +49 (0)441 9490852
(2,448 Views)
Hi Martin,
I just tried removing the first frame from a Flat Sequence in 8.0, and I did not get a crash...the frame was full of control terminals.
Perhaps you could give some more detailed instructions on how to reproduce the crash?  Better yet, perhaps you could attach a simple VI that demonstrates the problem?
-D
(2,444 Views)
