LV 8.20 features for the techno-weenies
I'll use this thread to post cool features I find in the LV 8.20 Upgrade notes.
Feature #1 Polymorphic Read From Spreadsheet.VI
Page 7 reads
The Write To Spreadsheet File VI and Read From Spreadsheet File VI are
polymorphic VIs. The Write to Spreadsheet File VI adapts to the value you
wire to the
format input. The Read From Spreadsheet File VI includes the
following instances: DBL, I64, and string.
How many times have you had to edit the VI.lib functions to changes the data types?
Ben
Message 1 of 8
(4,888 Views)
Page 36 include the following text
Performance Optimized with Constants
LabVIEW uses constant folding to optimize the performance of VIs. With
constant folding, LabVIEW stores constant values when it compiles VIs
instead of calculating them at run time. For constants wired to structures,
LabVIEW calculates the output values of the structures when it compiles
VIs and stores the values so they are available at run time.
You can display constant folding hash marks on the block diagram by
selecting
Tools»Options, selecting Block Diagram from the Category
list, and placing checkmarks in the
Show constant folding of wires and
Show constant folding of structures
checkboxes. When you place a
checkmark in the
Show constant folding of wires checkbox, gray hash
marks appear on the wires attached to constants that are constant folded.
When you place a checkmark in the
checkbox, gray hash marks appear inside structures that are wired to
constants. The hash marks might not appear in a VI until after you run or
save the VI.
LabVIEW 8.2 also folds computed constants you wire to Case structure
selector terminals and While Loop conditional terminals.
I'd like to see this one in action.
Ben
Message 2 of 8
(4,862 Views)
This is actually a great feature that I have enabled. The attached image shows a simple example:
Apparently, the two left FOR loop are reduced to a simple constant at point [A] in the compiled code. As you can also see, the data from the control is treated as a constant while inside the third loop.
Message Edited by altenbach on 08-25-2006 03:19 PM
Message 3 of 8
(4,837 Views)
Finally. A long time requested feature (example).
Oh, and that constant folding indication could come in handy too. Smiley Wink
___________________
Try to take over the world!
Message 4 of 8
(4,795 Views)
The improved start-up time of LV 8.20 is confirmed by LAVA users!
See here
Ben
Message 5 of 8
(4,702 Views)
Shouldn't the last line be hashed?  Isn't it a constant after all, if the numeric control is hashed, that is?
Message Edited by JoeLabView on 12-12-2007 08:12 PM
Message 6 of 8
(4,323 Views)
It would be hashed IF you would turn the numeric control into a diagram constant.
I agree that the description of folding in the LabVIEW help is probably a little bit too simplistic, because there seem to be several levels of constant folding. Some parts are folded at compile time (as described in the help), some are apparently folded when the VI loads (details), and some are dynamically folded for the duration of a structure, such as in location B in the figure.
In location B, the wire coming from the numeric is only a constant in the scope of the third FOR loop, so the output of the loop cannot be folded, because it depends of a control with variable value. However, during execution of the third FOR loop, it is a constant.
(see also this old post for an example of folding inside a structure).
Message 7 of 8
(4,316 Views)
Now I get it.  And I can (kind of)  see the benefit of turning on this feature.  It becomes another tool in the toolbox.  I'll have a look at you link later today.
Thanks!
Message 8 of 8
(4,274 Views)
