LV 8.6 Student Edition with Windows 7
In the middle of this semester, in which I'm taking a LabVIEW class, my laptop crashed.  I quickly replaced with a Gateway NetBook running Windows 7 Starter edition.  When I start to install LabVIEW 8.6 Student Edition, I get error windows:
LabVIEW Student Edition Software Suite
Error:  Windows SDK function returned an error (Error code-12)
End Error Report
Does LV 8.6 SE run under Win 7 Starter?  If not, will it run under a different (upgraded) version of Win 7?
Or am I just screwed?
(3,905 Views)
Search the forums for "error 12" and sort by date.  Several people have had problems using Windows 7.
See these two links for some possible work arounds.
http://forums.ni.com/ni/board/message?board.id=170&message.id=453874
http://forums.ni.com/ni/board/message?board.id=170&message.id=452664
(3,901 Views)
I am having a similar problem. I ma trying to install Labview 8.6 on an EeePC 1005HA running Windows 7 Starter Edition I don't get an error 12 message, it simply states "This product does not support Windows Starter Edition. Consult the documentation for operating system requirements."
I tired installing using the Troubleshooting Compatibilty mode as suggested in the other threads but got the same result.
Is there some sort of work around for this or do I have to pay for an upgrade? Will the Home version be enough?
Tim
(3,814 Views)
Hello all,
Versions of Windows 7 that do not have limitations causing problems with NI software include:
  • Home Premium
  • Professional
  • Enterprise
  • Ultimate
    Other packages will show various errors.
    I hope this helps,
    Kind Regards,
    Michael S.
    NI UK & Ireland
    Message Edited by sahpek on 12-24-2009 12:28 PM
    (3,503 Views)
