LV 8.6 application builder creates an empty installer
LV seems to create the installer O.K.  At least there are no error messages.  However, after I run the installer, the directory where the executable is supposed to be does not exist.  There are no error messages when running the installer.
(2,952 Views)
CORRECTION---
The installer does create an executable, but I can't find it, other than in the "Add/Remove programs" service.  I can add it and remove it, but not run it!!  The directory does not show in Windows Explorer, nor does it show in the Programs listing.
(2,940 Views)
Hi earl,
I hope you are doing fine. Here is the link that tells you how to build an installer. Particularly pay attention to step 3 -5 to see if you have set up the correct settings for source file to include in installer. Hope this helps
Fawad Nisar
National Instruments UK & Ireland
(2,933 Views)
Hi Eearl,
Did the advice you were given help?
I was wondering what OS your using and what path your trying to save too?
I would make sure your in admin mode.
Kind Regards,
James
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,914 Views)
Nisar F wrote:
Hi earl,
And step 6 shows you how to build a shortcut.
Ton
My LabVIEW Ideas
(2,897 Views)
