LV 8.6 instalation fails due to invalid drive
So I downloaded my copy of LV 8.6 yesturday.
Installing it was taking forever and after and hour and a half I decided to just go home and just let it run.
I came in this morning and there was a message saying that the LV8.5 installation failed because of an invalid drive J:
Drive J is my flash drive I use for transporting data around the lab it is attached to my company ID badge lanyard so I don't lose it.
I had removed it when I left last night.
What a drag having to start over again. I was hoping to come in this morning and start playing...
Message Edited by RTSLVU on 08-13-2008 09:23 AM
=== Engineer Ambiguously ===
Message 1 of 9
(4,183 Views)
Which version are you trying to install? R u trying to uninstall a version and install another?
Message 2 of 9
(4,167 Views)
Oops my bad, I was installing LV 8.6, but typed 8.5.
I have it installed, I just made sure there were no flash drives inserted or removed during the (2 hour long) installation process.
It just makes me wonder why the LV8.6 installation failed when I removed a removable drive that was not receiving any of the installation.
Message 3 of 9
(4,149 Views)
Are you using the platform DVD installer?
Thanks!
Warm regards,
Karunya R
Message 4 of 9
(4,145 Views)
Nope
NI LabVIEW 8.6 (English) Installer for LabVIEW 8.6
Is what I downloaded and installed
Message 5 of 9
(4,140 Views)
Just for completeness, could you also tell us your OS? (Mac, linux, Vista, XP, ....).
It it possible that some other driver letters changed when you removed the flash drive?
Is it possible that the temporary directory was located on J?
When it unpacked the installation files, what was the target folder you selected? Did you leave it at the default?
Message 6 of 9
(4,139 Views)
Windows 2000
No, at least not the "C" drive designator
I guess anything is possible, but the temporary directory should not have been there...
Yes, I selected the defaults C:\national insturments downloads\Lab View\8.6 is where everything was extracted to.
Message 7 of 9
(4,133 Views)
I think you have to uncheck the "install device driver" option when you install LabVIEW 8.6 if you don't have a driver DVD.
由 zenith 在 08-14-2008 11:10 AM
上編輯的訊息
Message 8 of 9
(4,112 Views)
I  received my set of LV8.6 disks yesturday.
I just realised that I have a CD-ROM and a CD-RW drive in my workstation...
But no DVD drive.Smiley MadSmiley Sad
Message 9 of 9
(4,081 Views)
