09-13-2010 10:01 AM
Just gone through our 3 year computer change out and our IS department has replaced the computer used on our Sound and Vibration room. When I load the above example, the timing property node that should write the sample clock rate simple has no properties available. If I right click on it I get a message "No properties" I assume that something has changed during the swap as it used to work fine. We are using LV8.5.1. Any help appreciated. Thanks
09-13-2010 10:07 AM
Did you reinstall DAQmx? Look for it on your Device Drivers CD/DVD. If you don't have it, you can download it from NI.
