LV FPGA Instruction Framework
Thank you for the quick response.
I just finished a similar test with LV2014 SP1 and FlexRIO 14.5 on a VM and the VIs seems to be there on the disk, although not in any palette (that doesn't matter in this case though).
Installing the FlexRIO driver is totally fine and that is very easy to do. What I wanted to avoid was telling the customer they would have to install the VST IDL or something similar.
Thanks!
Message 21 of 21
(1,456 Views)
