LV FPGA project sizes
When I try to organise my VIs for an FPGA project in my project I notice a huge increase in the size of my lvproj file.  It seems that LV sotres an appropriate signature value for each and every VI in my project as if it was a top-level VI.  While I understand the need for this in essence, given the absence of a build spec for 99% of these VIs, isn't this a bit of overkill?
We use a custom CLIP and adding the information required for this CLIP to the signature for each and every file is exploding our lvproj size.
I am aware that the workaround is to only include the top-level VIs in the project but I'd really rather be left the choice without having my SVN commits being negatively affected.
(2,452 Views)
You can avoid this behavior if you organize your VIs inside an lvlib and add the lvlib to the fpga target.
(2,399 Views)
OK, that might work.  But can't a single VI within an lvlin also be a top-level VI? Sounds like not completely logical behaviour.  Having the VI a member of a class doesn't have that effect.
(2,390 Views)
