LV FPGA signal IO timing
What would be the most code efficient way to measure how many 1usec ticks lapses between rising edges of 2 different DI's in Labview FPGA such as sbRIO-9629?
(443 Views)
Accepted by topic author Rafal_Kor
Add a U32 feedback node or shift register in a timed loop. On the first rising edge, reset and add one on each tick. On the second rising edge, stop and return the counter value.
https://tmesystems.net/
(397 Views)
