LV Help doesn't open the examples
The little buttons in LabVIEW Help which are supposed to open a relevant Example do not work on my machine. I suspect this is because I didn't install LV in the recommended spot. Mine's at D:\Labview. Is there a ini file or something I can edit to fix this?
Richard
(2,938 Views)
The help files are located in a subdirectory of the Labview.EXE installation directory by default.
Thus
Directory of C:\Program Files\National Instruments\LabView 7.1
which contains
--Labview.EXE
--Labview.ini
..... a couple of other misc files
More importantly a folder
HELP
which contains all the help files.
Make sure you actually installed them....
about 43 files of 17Mb
Message Edited by Conseils on 06-25-2005 07:51 PM
(2,932 Views)
Yes, the HELP directory with 17MB of files is there. Help isn't the problem, it's that Help doesn't open up the Examples as it should - when you click the little buttons (see attached jpeg). I've installed LabVIEW at D:\LabVIEW, so maybe there's a pointer missing?
Richard
(2,906 Views)
I get that problem too... I know they're installed, since I can find them manually, but they just won't work with those pointers... bug in LabVIEW?
(2,899 Views)
There are several reasons that the buttons in LabVIEW Help may not work. Here is a knowledgebase from our website that covers some of the most common reasons for this behavior. Take a look and see if it points you in the right direction. Have a good day!
Tyler S
(2,886 Views)
