LV Installer Run exe at end_Cmd line arg
Hi guys,
Under Installer Properties of LV 2014.
Sentinel HASP (dongle) silent driver installer haspdinst.exe
Trying to pass command line inputs according to the following instructions but not working.
haspdinst <mandatory switch> <optional switch>
I just want to use the mandatory switch -i
I have check in the Windows cmd and haspdinst -i works but not from LV installer.
Is the format I'm entering incorrect?  The instructions below also state that / can be used as switch character.
(3,512 Views)
Accepted by topic author battler.
Solution:
Leave out haspdinst
Only use -i switch under command line input
(3,487 Views)
