LV Installer include RTE-Do Not Reboot PC after Install
Hi guys,
Including the LV RTE in a LV-built installer, how do I stop the customers PC from rebooting after install?
I've seen there is a command line option REBOOT=ReallySuppress
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAE4SAO&l=en-AU
However, I'm not using the command line to install the RTE and don't want to do it like that (I'm using command line settings in the installer to run the EXE - However if the RTE is not installed then this doesn't work either).
Thanks.
(2,871 Views)
Did you try the command explained in the Silent Installation Section of this document?
Customize and Automate Installation of a Suited Installer
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LeTSAU&l=en-US
(2,824 Views)
