05-05-2008 12:03 PM
05-05-2008 12:06 PM - edited 05-05-2008 12:07 PM
05-05-2008 12:08 PM
05-05-2008 12:10 PM
05-06-2008 06:51 AM
smercurio_fc wrote:
And, you can also use the error cluster to force data dependency.
05-06-2008 09:04 AM
That's a bit excessive, in my opinion. Every programming construct has its use. It's their misuse due to inexperience that's the problem.
@JoeLabView wrote:
It is a formal requirement within my company that forbids the use of Local Variables and Stacked Sequence Structures.
05-06-2008 09:43 AM
I agree with you..
Having this rule forces you to come up with better alternatives and avoids becoming lazy while coding the solution 😄
05-06-2008 09:50 AM - edited 05-06-2008 09:50 AM
05-06-2008 10:34 AM
Thanks, folks! Now I see what Proven Enthusiastic Veterans are and how enthusiastic they can be. You guys are making people's learning more fun, and that is very kind of you.
I have tried both local variable and property node. Of course they both worked.
Thanks again!
05-06-2008 01:12 PM
