LV PDA 8.2 Hex String to Number Primitive BUG
Attached is a LV Project used with a Windows Mobile 5.0 device.  The project is set to enable debugging and a breakpoint is set at the Hex String To Number VI primitive.  When I wire in a U8 type input, my WM5.0 device consistently crashes.  When I unwire the U8 type input, everything works fine.  Try the attached file with a real WM5.0 device.  Emulator mode may still work with the U8 input wired.
(4,151 Views)
rberger:
I was able to reproduce this issue. I created a VI that has a string control and default integer going into "Hexadecimal String to Number.vi". I indeed realized that setting the representation to "U8", "I8" causes errors on the PDA. I will look into this issue again and get back with you.
Rudi N.
(4,125 Views)
rberger:
I just wanted to let you know that I have brought this issue up to R&D. They are now aware of it, however I cannot give you a timeframe on how long it would take to get back with me. I will surely contact post on this forum as soon as I have something to report.
Again, thank you very much for bringing this up to our attention.
Best Regards,
Rudi N.
(4,058 Views)
