LV PDA 8.2 Initialize PDA Button.vi BUG
The Initialize PDA Button.vi for PDA 8.2 is not consistent with prior versions.  Here is what the example VI states at C:\Program Files\National Instruments\LabVIEW 8.2\examples\PDA\key events\Key Events Advanced - Pocket PC.vi
Using key events does not override the mapping of application keys. By default, LabVIEW PDA applications do not receive an event when a key that is mapped to an application by the OS is pressed while a LabVIEW PDA application is running. The mapped application launches. You can use the Initialize PDA Button VI to suspend the mapping of application keys while the LabVIEW PDA application is active.
If you load the project and download the exe, in prior version ALL keys that were mapped to applications became disabled.  Now only the up, down, left and right keys are disabled.  This is a bug.  Please fix since it looks like it's just calling the input.dll.  Can NI submit to us a new DLL??
Robert
(3,401 Views)
I have filed a corrective action request (CAR) to R&D for this issue, and have included your sentiments regarding having the problem fixed.
The CAR ID is: 42CA2GSQ
Best Regards,
JLS
Official Note:
This was reported to R&D (42CA2GSQ CAR ID) for further investigation.
Best,
JLS
Sixclear
(3,389 Views)
