LV PDA 8 : Unbundle by Name Bug
In the previous LV version, clusters were not supported. They are now in the LV 8 version, but the Unbundle by name function do not work on sub-clusters (see the attachment). A similar (and probably identical) problem had already been reported here with the unbundle function in LV 7. Seems that somebody is not doing his work...
The workaround consists in chaining two Unbundle by Name operators.
Chilly Charly    (aka CC)
(4,452 Views)
Hello CC,
As mentioned in the thread you referenced, a corrective actiion request for this issue was filed in LabVIEW 7.1.  To date, this issue has been deferred for a later release of LabVIEW, which explains why you are still seeing the behavior in LabVIEW 8.0.  Just wanted to give you an update on the issue and that the LabVIEW team is aware of it.
Thanks again for all your great work on making the product better!
Wendy L
LabWindows/CVI Developer Newsletter
(4,406 Views)
This was reported to R&D (# 3EEEC41R) for further investigation.
Travis H.
LabVIEW R&D
(4,252 Views)
Accepted by topic author chilly_charly
This was reported to R&D (# 3EEEC41R) and was fixed in LabVIEW 8.2 PDA. Here is a link to the current evaluation software download for LabVIEW.
Thanks!
Travis H.
LabVIEW R&D
(4,140 Views)
