LV Runtime install problem
Hi
Got a question: when installing LabView 2018 runtime on Windows 8 I get an interesting problem. Some of the buttons of the runtime installer do not work.
I have tried two options:
- downloading installing just a runtime
- building an installer from development environment and installing runtime with it.
In first case I could not select radio button for accept licence agreement (I tried scrolling trough he license text), in second case at one point I could not use next button. In both cases cancel buttons worked. Some other buttons like "back" did not work either.
I see that LV Runtime 2018 is compatible with Windows 8.1 not 8 but can this be the issue?
I have never experienced buttons not working on the installer.
(.NET was installed)
Regards
(1,882 Views)
Accepted by topic author WinXP-Allways
Take a look at the compatibility chart.  I don't think that combo of LV + Windows is supported.  I'm guessing this applies to the LV RT as well.
Oops you already did.
Bill
CLD
(Mid-Level minion.)
(1,833 Views)
