I can't answer your question directly. But let's assume for the sake of argument that the LV runtime can be installed to an external device. I think they will still have problems with their IT dept. because they would still have to install the LV runtime engine into the Windows environment which would affect the registry and probably .dll's which get installed to the system directories, even if you specify installation to a location other than the c:\ drive.
Message Edited by Ravens Fan on 08-20-2007 11:05 PM
