LV-SignalExpress2011 - Cannot save to .LVM - Option is disabled in the Step Setup
Hello, for some reason I cannot choose the option to save as .LVM in my SAVE TO ASCII/LVM step.
The input signal is a DBL Data output from a LabView 2011 Plugin.  The data plots fine on the Data Graph... I can only save as ASCII.TXT.  I want to save as .LVM because I want to include a time-stamp for every sample.
Attached is a screenshot of the step setup for the FILE EXPORT TYPE - You'll see the pull-down is gray'ed out...
Any ideas why this is disabled?
(2,155 Views)
You should post to the express board. However, I can tell you that since a dbl array has no time stamp information, it does not matter that you can't select lvm.
(2,153 Views)
