LV Test Executive reloading
Is there anyone having a problem to run the test sequences in Labview Test
Executive V5.1 ? I must reload the Test Executive every 4 or 5 full test
execution. Otherwise, Test Executive can not communicate with instruments
in ATE and the test sequence displayed all false error measurements. I don't
know if it could be the case of memory leaking !
I am working with labVIEW 5.0.1 for Windows 98
Thanks in advance.
(2,775 Views)
Check to see how you are opening and closing VISA references. If you keep
opening references without closing them afterward, you can see this sort
of problem. I use TestStand instead of Test Executive but what I do is open
references to all instruments in a setup step and then close them in a cleanup
step.
"vanhoa dao" wrote:
>>Is there anyone having a problem to run the test sequences in Labview Test>Executive
V5.1 ? I must reload the Test Executive every 4 or 5 full test>execution.
Otherwise, Test Executive can not communicate with instruments>in ATE and
the test sequence displayed all false error measurements. I don't>know if
it could be the case of memory leaking !>I am working with labVIEW 5.0.1
for Windows 98>>Thanks in advance
(2,775 Views)
