LV Unit Test Framework and Enumerations
We're starting to explore the unit test framework (UTF) (since it comes with the dev suite now), and I was trying to figure out if there's a way to get the UTF to know about the labels associated with enumeration controls? The UTF seems to know that a given input or output of a VI is an enumeration (the data type gets populated as Enum U16, for example), but it doesn't seem like the label information goes along with that.
Is there a checkbox or clicky-widget I'm missing somewhere?
Thanks -
Tom
(2,874 Views)
Have you tried using enum property node?  I believe you should be able to obtain the labeled text that way.  The following link shows how to extract the strings associated with an enum type.
Obtaining Enum Elements in String Format:  http://ae.natinst.com/public.nsf/web/searchinternal/7bd127b0c8ac37d3862571af004df697?OpenDocument
Isaac S.
Isaac S.
(2,853 Views)
Issac,
When I tried to navigate to the link you suggested I could I got a page load error.  Do you have a better link maybe?
WireWarrior
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
(2,837 Views)
My apologies please try this link instead:
http://digital.ni.com/public.nsf/allkb/7BD127B0C8AC37D3862571AF004DF697?OpenDocument
Isaac S.
Isaac S.
(2,823 Views)
