LV Version vs. LV Runtime Version for NI-SCOPE Requirements
I am using the PCI-5112. When I look at the hardware in MAX it says something along the lines "Using old version"
I would like to upgrade to the most recent version but I am confused about the requirements for different versions of NI-SCOPE.
For example, in MAX, under Software, I have:
LV 8.2
LV Runtime 8.2.1
LV Runtime 8.0.1
LV Runtime 7.1
And for example the 3.6 version of NI-SCOPE: http://joule.ni.com/nidu/cds/view/p/id/1492/lang/en
They say Labview 8.2.1
Now since I have 8.2 and the runtime 8.2.1 would I be fine?
As well I noticed a discrepancy. On the old computer which has the hardware for the versions of NI-SCOPE it says:
NI-SCOPE (IVI) - 3.4.0f3
NI SCOPE Soft Front Panel - 2.8
However on the new machine I installed NI-SCOPE 3.8.7 and I have:
NI SCOPE Runtime - 3.87
NI SCOPE Soft Front Panel - 3.8
Which seems a lot more reasonable since they are both 3.8. Any reason why on the old computer there would be this difference?
Thanks for the help. Cheers.
(2,657 Views)
Accepted by topic author AFolly
Hi AFolly,
I checked with the installer for NI-Scope 3.4 and it includes Soft Front Panel version 8.2.1, so this is expected. However, I do believe that you will need to have LabVIEW version 8.2.1 in order to properly support version 3.6 of NI-SCOPE.
Kaitlin N.
(2,602 Views)
