LV crashes when I Create a subVI
I am a newbe with LabView, and I am working through some courses using the Student Edition.
Every time I mark everything on this simple vi (written to try to isolate what conditions are causing this problem) LabView does a complete crash and burn. This only happens when I am using a local variable, although I am not sure I have implemented it correctly.
Attached is the VI and the LabView error report.
DerekS
(2,790 Views)
The control reference seems to be the problem. And it isn't crashing in LabVIEW 7.1, so it looks like it got fixed.
There are some workarounds, though:
(1) Don't use control references. If you need to remember state information, there are other ways of doing that, such as shift registers.
(2) Don't use the "Create SubVI" function. Just create a VI on your own.
HTH,
Lars
(2,790 Views)
In your program there is no need of the sequence structure or even the local variable. I have attched a modified version of the vi that gives the same results as before but this one does not crash LabVIEW 7.0 when you try to create a subvi by highlighting. On another note, it is best if you create a subvi using the connector pane. Read on help for "creating Subvis from selection" on LabVIEW help to know what are the pitfalls when you create a subvi by highlighting.
(2,790 Views)
Thanks for the input. I have indeed found out that this is a 7.0 bug, which it sounds like has been fixed. I have found another way to implement the design I was looking for.
Cheers,
Derek
(2,790 Views)
