LV dial up
Hi all again,
Does anyone know how to use labview to dial up a connection to the internet
(or to a remote server) using a modem?
I have an application that may need to do this to periodically download data
from a remote site. I also have an application that must send text messages
to pagers.
any ideas?
Cheers
John
Message 1 of 10
(5,643 Views)
If it is a TCP/IP application, both Macintosh and Windows will
automatically dial up to your ISP when data is requested or sent over
TCP/IP. To use a modem to dial a pager number, send it the appropriate
AT commands (to the serial port if using a serial modem). For example,
to dial the numeric pager 555-5342 and leave the numeric message
555-1744:
ATDT 5555342,,,555*1744
ATH
If I remember correctly, this will dial with DTMF (touch-tone) the
number 5555342, wait for about 6 seconds (2 seconds per comma) then dial
555*1744 (the * leaves a space on most numeric pagers). Wait before
sending the ATH, I believe that it is the hangup command, though the
modem will probably time-out after 30 seconds or so anyway.
John Cronin wrote:
> Hi all again,
> Does anyone
> to pagers.
> any ideas?
> Cheers
> John
Message 2 of 10
(5,643 Views)
555-1744:
ATH
John Cronin wrote:
> Hi all again,
> Does anyone
> to pagers.
> any ideas?
> Cheers
> John
Message 3 of 10
(5,643 Views)
HEY did this work for you!!???
because i'm trying to do the same thing but my project it's a little
different...can you please email me back to see if we can exchange some
info....thanks
John Cronin wrote:
> Hi all again,
> to pagers.
> any ideas?
> Cheers
> John
Message 4 of 10
(5,643 Views)
See http://www.pcia.com/wireres/protocol/links.htm and look for a copy of
the TAP protocol to page alphanumeric pagers.
See also http://braddye.com/input.html
Jean-Pierre Drolet
Fausto Meraz a écrit dans le message :
3935330D.8BE3ED0F@spaceelectronics.com...
> info....thanks
> John Cronin wrote:
> > Hi all again,
internet
data
> > from a remote sit
messages
> > to pagers.
> > any ideas?
> > Cheers
> > John
Message 5 of 10
(5,643 Views)
You can log onto the example programs database and search for hyperterminal. There is a program there which emulates the windows Hyperterminal program. This is simply a terminal to communicate and dial modems.
Message 6 of 10
(5,643 Views)
I have central location with GPRS modem and PC. At remote location there are GPRS routers transparent to Modbus and Modbus device. For GPRS I have coorporate APN.
I make dial-up connection from PC to GPRS modem and I can ping remote locations. I want to make LabVIEW application to read data from remote locations. So, I have to encapsulate Modbus into TCP/IP. How to do that?
Message 7 of 10
(5,089 Views)
I don't have an answer to your question, but I would strongly suggest that you start a new thread rather than trying to resurrect a 7-year old thread which makes no mention of Modbus. Smiley Wink
Message 8 of 10
(5,083 Views)
The producer of GPRS router gave me the wrong information. They used UDP, no TCP/IP.
It's work.
Message 9 of 10
(4,897 Views)
Well, good to hear you were able to resolve the problem. It took them 10 months to get you an answer? Smiley Surprised
Message 10 of 10
(4,880 Views)
