LV doesn't match Excel trendline equation
I know, another LV vs Excel issue. I can't seem to find satisfaction from the search so here it goes.
I have plotted some numbers in excel and had the chart display the trendline equation.
I then tried the same thing in LV.  The slope matches but the intercept does not.
Excel computes y=1.0096x + 0.4052.  LV gets y=1.0096x +.4066.
Is there something i can do to make LV match excel?
I can't change the excel sheet as it is used to calibrate some of our stands.  I'm trying to make the system automated so I don't have to use the sheet to do the computing and using LV to just enter the data in the excel sheet for record keeping.  I can just use ActiveX to exctract the trendline equation from the chart but I'd rather have LV do it.
X Values are:
-0.32268
10.8489
21.9037
33.1427
44.3617
33.2487
22.0309
10.6525
-0.4177
y values are:
0.00
11.30
22.60
33.90
45.19
33.90
22.60
11.30
0.00
-Keith
Message 1 of 8
(3,709 Views)
I just put both into Excel and LabVIEW and I got the same answer for both, y=1.0096x + 0.4066
Mistype maybe???Smiley Surprised
I am using Excel 2003 and LV8.2.1
Kenny
Message 2 of 8
(3,696 Views)
I'm using LV 7.1 and the same version of Excel.  I just created a new graph using the same data and I still get 1.0096 + 0.4052.
The chart is an XY scatter.  Is that significant?
Message Edited by kmiller on 07-25-2007 02:58 PM
Message 3 of 8
(3,691 Views)
Here is my spreadsheet.  I am using the xy scatter as well.
Kenny
Message 4 of 8
(3,684 Views)
Your sheet comes out correct on my computer.
Here is my excell chart.
Message 5 of 8
(3,675 Views)
I have found the problem.  Its the digits of precision that are displayed in the data . I compared the two data, yours and mine and they match but I got different results so I subtracted them and got a number difference.  My data has 3 hidden digits.  I plugged in the corrected data and everything is correct now.
Thanks for your help! I wouldn't have gotten here this quick if I didn' have another pair of eyes looking at it.
Message 6 of 8
(3,670 Views)
I hate when that happens Smiley Very Happy
Glad to hear you found it.  Good luck
Kenny
Message 7 of 8
(3,667 Views)
Glad you found your problem, but something else to be aware of is that Excel only uses single-precision floats, where as the default for LV is double-precision. This means that you can get different results due to differing rounding error.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 8 of 8
(3,655 Views)
