LV error on Windows 7 with NI Gmath VI
Hi urado,
I want to make sure that you've done the step where you "replace with subVI contents". We've seen that fix this issue under similar circumstances.
Also, what patch version of LV do you have? I would recommend updating to the most recent, f2 patch. That may resolve your issue.
http://www.ni.com/product-documentation/54795/en/
Best,
Ben
Message 11 of 16
(893 Views)
I install f2 patch and you are right. My issue was solved with this. Thank you Ben for this.
Best regards
Rado
Message 12 of 16
(877 Views)
I'm glad I could help!
Have a nice day,
Ben
Message 13 of 16
(870 Views)
For this particular problem that was corrected by the f2 patch, which Issue ID is it?  I don't see a description that matched the original problem described.
Message 14 of 16
(866 Views)
Hey playerm1,
I would expect this to be fixed as a consequence of ID 704579. The symptoms from that ID are similar to this issue and I suspect GMATH uses these VIs.
Best,
Ben
Message 15 of 16
(844 Views)
I noticed that this issue is still present if compiled object cache isn't clear before I build the application...
BR
Rado
Message 16 of 16
(823 Views)
