LV .llb icon inserts as drawing
hi,
I'm using a LabVIEW contributed driver/library where one of the
library icons inserts into a diagram as a diagram, not an icon -
a bit like the reverse of "Create SubVI".
Only one icon in this .llb exhibits this behavior.
Is this a just a strange bug in this library, or a subtle option?
thanks,
Dave
(2,754 Views)
Yes it is an option.
You have to Edit Controlls & Function Palettes...
In your User Libraries, either add the VI to the Control Palette or add the
the VI to the function Palette and select the "Merge VI" option for the
icon.
In both cases, the diagram of the VI with all its controls will be copied to
the diagram when you select the VI in the Controls or Functions palettes.
Jean-Pierre Drolet
a écrit dans le message : 38E8EE10.A14DFD31@fnal.gov...
> hi,
> thanks,
> Dave
(2,754 Views)
