LV printing problem
I used Report Generation to implement printing of front panel. Everything is nice. Then I built a appalication and tested the printing function on a computer without installing LV6.02. I got the following error:
failure: image.cpp, line 11472
in LabVIEW 6.0.2.
But if I install the LV6.02, everything will be nice.
It seems that the "Crimal" is Runtime engine.
How can I do?
For most of my usesrs, the LV is not sure to be installed.
I installed Runtime engine 6.02. The OS is Win95/98.
(2,904 Views)
often the problem is the video card driver
download the latest and try again
greetings from the Netherlands
(2,903 Views)
This article from KnowledgeBase might help you:
'LabVIEW Internal Errors (Failure in XXX.c / XXX.cpp at line YYY)' (http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/01b186b5ceb1d07786256747000f4319?OpenDocument)
Good luck !
(2,903 Views)
The 1200 family cards have some special properties different from the common E serials. It was ignored.
The following is the reason that causes the problem.
Unlike other boards in differential mode, for the 1200 family of data acquisition boards (DAQCard-1200, PCI-1200, Lab-PC-1200, DAQPad-1200, and Lab-PC-1200AI) the channels names of the four differential channels are 0, 2, 4, and 6 as opposed to 0, 1, 2, and 3. So, in your scan list you have to specify (in descending order) "6, 4, 2, 0" for your four differential channels.
The patch is available in the ftp://ftp.natinst.com under the name Biobench12P.exe.
(2,903 Views)
