LV programming
Dear sir,
I am using LV to capture an image file (bmp or jpg). I can show it on
screen. However, I don't know how to covert two image files so that I can
do mathermatical comparison.
I need to compare two capture images (one template and one sample) and
output a signal if they are different. [e.g. An surface mount IC is compare
with an IC rotates 90 degree (mis-positioning) and output a failed signal].
I can only use LV because I don't have any frame grabber or IMAQ. Pls
advise if this is possible.
Rgds,
TM
Message 1 of 1
(2,805 Views)
