LV slows down extremely when having large contents in clipboard
Hello to all participants,
let me, as the initiator of this discusssion, close this with the following ....
As Jochen mentioned, he, and i also had never before this effect.
My reason for the upcoming of this is, that the way how user works changes
dramatically. In earlier times there wasnt that amount of multimedia and even not on
measurement pc. Now each pc has several tasks.
 because of the processor power we use them as measurement AND office and ......
whatever pc too.
So its a change in user behavoir which cannot easyly been forseen.
I ever recognized that NI was very quick in adaption to changes in whatever reqirements.
Let me thank all the people of NI for this. Thats the reason why we choose to go with NI.
Best regards
and a Merry Christmas
Hartmut Jacobi
Message 11 of 23
(10,846 Views)
@Ben wrote:
Hi Jochen,
I appreciate you stepping forward and being upfront with us about what is happening here. Knowing wha the issue is, is half the battle.Smiley Happy
What is an effective technique for minimizing or clearing the clipboard so I could code around this issue?
Ben
You could execute the VISRV Clear Clipoard,vi (LabVIEW 7.1) in the attached archive. This will probably just remove the contents of the clipboard and may be annoying to a user since he doesn't usually expect the clipboard contents to just disappear unless he explicitedly did a Copy, Cut or Clear action.
Or you could also use the other library clipbrd.llb (LabVIEW 6.0 and higher) in the archive which is Windows only but contains a rather extensive set of functions to copy and paste bitmaps and text to and from  the clipboard and also otherwise control it. You could then extract the cli[bopard contents, store it somewhere and clear it to put it back later on, although that will have its own implications as the user may in the meantime already have put something else in the clipboard.
As to if this is just a changed user behaviour I'm not really sure. I believe LabVIEW did use delayed clipboard handling in the past where it only synchronized with the external clipboard when a user requested a clipboard action or Windows informed LabVIEW that it needs a previously notified clipboard change to appear now in the clipboard since another application requested it. But if I'm not mistaken, this had some other difficulties and problems so it may have been that LabVIEW recently changed its behaviour to fix those problems.
Rolf Kalbermatter
Message Edited by rolfk on 12-16-2005 10:23 AM
Rolf Kalbermatter  My Blog
Message 12 of 23
(10,844 Views)
Hi there,
I just wanted you all to know that this issue is known within NI and is something that is taking a long time to work out because it is part of a larger implementation in the LabVIEW code itself. I assure you though they are working to fix the issue - so expect to see it in future versions of LabVIEW. See this post. Thanks!
Stephanie
Message Edited by Stephanie J on 06-06-2007 07:48 AM
Message 13 of 23
(10,467 Views)
HI Stephanie,
Could you please post the CAR associated with this issue?
Ben
Message 14 of 23
(10,461 Views)
CAR ID: 3YJ87JCM
Message 15 of 23
(10,456 Views)
Thank you!
Ben
Message 16 of 23
(10,452 Views)
Dear Rolf Kalbermatter,
Sorry for just giving you single Kudos...:(
Very Very useful and Important post and attached sub functions.
Thanks a ton...
Hemant
India
Message 17 of 23
(8,932 Views)
New Version of the library in LabVIEW 2009 with adaptations to work for LabVIEW for Windows 32-bit and 64-bit.
Also changed the license from GPL to BSD 3-clause.
Message 18 of 23
(6,288 Views)
Yessss!!!!!
Thankyou Rolf , you saved my day.
Message 19 of 23
(5,845 Views)
Hi Rolf,
I'm having an issue with colors.
I thought was because of the resize function I used, but now i believe the color table produced by this library is not correct.
Original:
After passing thru clipboard:
the code:
 What do you think about it?
Message 20 of 23
(5,807 Views)
