LV upgrade to 2012 from 2010 now GPIB doesn't work
No, you have error 0.
What about the driver or the simple VISA example? Same error?
Message 11 of 20
(1,062 Views)
In the VISA_GPIB_Resource drop down list the GPIB address 7 does not show up after I choose Refresh.
Message 12 of 20
(1,058 Views)
I'm running out of ideas. I can only suggest that you completely uninstall NI-VISA and NI-488. Reboot your pc and install again.
Message 13 of 20
(1,048 Views)
Are you sure it's at address 7?  I mean, I understand that LV was the only thing that was changed (at least as far as you know).  Do you think maybe someone could've swapped equipment on you?
Bill
CLD
(Mid-Level minion.)
Message 14 of 20
(1,045 Views)
Here, is another screen shot. The address is 7.
Message 15 of 20
(1,040 Views)
Could this be related to not have Full Admin privileges on my computer account?
Message 16 of 20
(1,028 Views)
How do I completely uninstalled VISA and 488? Should I just remove all Labview?
Message 17 of 20
(1,024 Views)
Add/Remove Programs and you should see National Instruments Software listed. I would start with just the drivers I mentioned.
Not being an admin should only affect your ability to change settings in MAX.
Message 18 of 20
(1,022 Views)
This is suspicious.  Does the device appear and disapper from MAX when you refresh devices as well?  If MAX is reliably seeing the GPIB bus then the drivers are correctly installed and it is the VISA link to LabVIEW that may be the problem.
You can try re-installing the lastest GPIB drivers https://www.ni.com/en/support/downloads/drivers/download.ni-488-2.html
And the latest VISA drivers.  https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html
LabVIEW ChampionLabVIEW Channel Wires
Message 19 of 20
(1,012 Views)
I reinstalled Labview and installed the latest drivers and things seem to be working now.
Thank you to everyone that took the time to provide comments and suggestions.
joe
Message 20 of 20
(1,001 Views)
