LV wants to install NI DSC Commontools 2014
Not sure where to post this. I've never seen anything like it.
Since yesterday when I start LV it comes up with an installation window attempting to install NI DSC Commontools 2014. I have to press cancel twice to get it to stop. I already tried deleting the LV configuration file and checking startup in msconfig. What could be causing this? Thanks in advance.
PaulG.
Retired
(3,887 Views)
Hi Paul,
The DSC_Common_Tools component is only included with the DSC Module (Datalogging and Supervisory Control). Do you have this installed?
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(3,827 Views)
LV2013 DSC was installed but not activated. I removed it.
It doesn't ask for the DSC Common Tools anymore. Now it wants the disk with LV8,5 runtime engine.
Smiley Indifferent
PaulG.
Retired
(3,789 Views)
Hi Paul,
Glad that resolved the odd DSC component.... but now it saying it needs 8.5 RTE is another oddity. Do you have a program that would need the RTE? Whether that program is a VI or a compiled executable.
When does this new pop-up window occur?
Andrew T.
(3,760 Views)
I had 8.5 installed on this machine and removed it. I still get the request for the disk to install 8.5 runtime engine. This is absolutely bizarre.
PaulG.
Retired
(3,738 Views)
Paul,
That is pretty odd. Is there any chance you stil have a custom application that uses the LabVIEW 8.5 Run-Time Engine?
Another thing you can try is opening up Programs and Features -> National Instruments Software. Do you see anything on this list related to NI LabVIEW 8.5?
Andrew T.
(3,722 Views)
