LV2009 Epics Process Variables Alarm Values
Hello, I am using the epics server under LabView 2009. I wanted to be able to set the alarm values of these process variables such as hihi and lolo so I figured I would install the DSC module since that allows you to set those values under shared variables. I found that very few of these alarm values get transfered over to the process variables when you bind a shared variable to a PV. Low seems to work but high doesn't. Very strange.
Is this a bug?
Message 1 of 1
(2,856 Views)
