LV2009SP1_32.exe failed to initialize properly (0xc0000005)
I downloaded LV2009SP1_32.exe from NI web site (twice, to be sure). I am trying to install it on WinXP 32 bit. I am getting error "The application failed to initialize properly (0xc0000005).  Click on OK to terminate the application."
Any hel with what co be wrong?
(3,572 Views)
Have you seen this? I believe that the link will help point you to a solution for that particular error.
-Zach
(3,549 Views)
Since LV2009SP1_32.exe is the only program that have this error, does it mean something is wrong with NI registry entries? How to recover from it, besides reinstalling OS?
(3,530 Views)
Hello Fedor,
I would suggest using
Registry Mechanic
http://www.0xc0000005.com/registry-cleaner.html
to try fixing your registry issue.
Andy Chang
(3,514 Views)
