LV2010 Build Application: Error 1498 occurred at Get LV Class Default Value.vi
Hello Sam,
I am getting the same error using Labview 2011.
I just installed it. Opened old 8.2 program. Program runs fine , no isues, but when I try to build executable I get Error 1498.
Are there any other fixes for 2011?
Message 11 of 16
(1,662 Views)
Rus,
Have you tried repairing LabVIEW? Go to start > control panel > add and remove programs > National Instruments > modify (repair) LabVIEW. This will go through and make sure it has the correct paths to the application builder.
If that doesn't work, can you please post some information about your code?
Katie
Katie Collette
Message 12 of 16
(1,639 Views)
Hello !
I got the same error as the First Post. I even tried to Repair it according to solution. But still same problem. Can it be possible that If my project contains " Files with No callers " then they give this error 1498 ? As I am little lazy to clean up my project right now and have other important work.
Message 13 of 16
(1,409 Views)
Is this error occurring in LabVIEW 2010 or a different version?
Chase
NI Technical Support Engineer
Message 14 of 16
(1,392 Views)
Sorry Chase.E for such a late reply, as I was busy in other project. I got the Solution by re-installation of Whole LabVIEW and all its Modules. I took almost 5 hours but finally done. Thanks you... This error was occurred in LabVIEW 2011...
Message 15 of 16
(1,380 Views)
Здравствуйте я использую LV 2020 СЕ и не могу создать RT приложение для RPi3b. Вылетает ошибка 1498 пробовал, восстановить данные это не помогло, скачал NI System Configuration тоже не помогло, + где то читал что в сообществе отсутствует каталог nisyscfg но не знаю как его скачать. RT приложение нужно что бы при включении RPi3b в сеть сразу запускалась программа те автозапуск, с созданием обычного приложение EXE проблем нет но на Rpi3b оно  не работает. автозапуск настраиваю через крон таб это правильно или надо как то по другому. и из за тих ошибок в LV надо ли пробовать переустановить или это не поможет ? или пробовать скачать профессиональную версию. ??? что делать подскажите пожалуйста.
Message 16 of 16
(885 Views)
