LV2010 apps not working on Win7-64bit? Check this...
Just thought I would pass along something that I could not find in a search, but eventually discovered myself.  I just got upgraded to a new PC with Win7-64bit, and even after installing the LV2010 runtimes, device drivers, etc., even the simplest compiled LV .exe application (a toggle switch connected to a light) would not run. Windows was no help, just saying that the program caused an error and was being closed.  Eventually I checked the Event logs, and found the issue was related to a file named niwebserver.conf.  Long story short, a few years ago I was experimenting with remote panels, and had turned on the Remote Panel Server (Tools -> Options -> Web Server -> Enable Remote Panel Server).  The experiments were abandoned, but I never turned the server off.  It turns out the configuration file generated (niwebserver.conf) is incompatible with Win7-64.  The best solution is to recompile with the server disabled.  If not possible, and remote panel is not being used, try deleting the niwebserver.conf file, as this will sometimes work.
(2,431 Views)
Thank you for sharing these info!
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,416 Views)
