LV2011 BUG: Export to Excel
I believe this is a bug in LV2011 - haven't tested it in earlier versions.
I have a Mixed Signal Graph containing 4 plot areas, comprised of 16, 2, 2, and 2 plots. Every plot contains X/Y data, not waveform data. In the bottom two plot areas, I have two plots in each are, and have split the Y-scale to have one plot's scale on the left and the other plot's scale on the right.  When I right-click the graph and select Export to Excel, all of my data is imported into the excel spreadsheet except for the data associated with the left-hand scale of my two split plots. The column headers show up, but there is no data!
Also, does anyone know if there is a way to tell the Export function to only use one X-scale column?  All of my plots share the same X data, but because they are all X/Y plots, I get 22 copies of it (one for each plot).
(2,375 Views)
Would it be possible for you to post a small sample version of your code that reproduces your problem?
Thanks!
Ryan
(2,362 Views)
