LV2011: loading snippets you can't "ignore all" missing items?
just stumbled about that one:
When loading a snippet in LV2011SP1 with several missing items I wanted to "ignore all" - but LV kept asking for each and every missing item again...
The snippet I used is attached to that message.
So is this bug already known? Searching for "snippets ignore all" doesn't gave any results...
(3,240 Views)
I think I reported that before elsewhere (~late Nov 2011). No CAR 😉
(3,230 Views)
If the snippet was created by the Code Capture Tool (in my opinion much better than the built-in LabVIEW snippet item), I wonder if it would have the same problem.
(3,224 Views)
Hey Altenbach,
could you post your old service request number. Since this is not concidered a major inconvenience it will take time to be fixed. Nevertheless I would like to make sure, that it can be found on the list for known issues.
Kind Regards
(3,194 Views)
I was trying to post this Bug, but found to be already reported. This is still present in 2013 SP1 also, is there any update on this?
(3,146 Views)
