LV2011 run time engine error
Somebody knows why I hit a run time engine error when I select runtime adapter in teststand? If I choose dev environment, there is no error and the vi executes.
Message 1 of 14
(4,078 Views)
Did you check the possible causes which TestStand pointed out?
Message 2 of 14
(4,067 Views)
What is the difference in dev mode then in run time mode?
Message 3 of 14
(4,065 Views)
When using the "Development Environment" for the LabVIEW Adapter the VIs will be loaded using the LabVIEW Development Environment (LabVIEW.exe) at your system.
When using the "Runtime" TestStand is using the LabVIEW Runtime Engine to load the VIs.
Im pretty sure this is also documented within the TestStand Help.
Christian
Message 4 of 14
(4,062 Views)
I understand. But the dev module and run time module have the same version. And only the run time complains that the version of some sub vi's is not correct. Or is there another isuee?
Message 5 of 14
(4,057 Views)
Try to do a masscompile of the VI and see if you get any errors.
Christian
Message 6 of 14
(4,048 Views)
Do you mean a build of this vi?
Message 7 of 14
(4,043 Views)
Ah, I see..
Message 8 of 14
(4,032 Views)
I did a masscompile of the vi's and they report no error. See log file.
Message 9 of 14
(4,011 Views)
Hello JoVMo,
I think the reason and solution for the issue can be found in this KB:
http://digital.ni.com/public.nsf/allkb/24A8C9552C01D7368625735600768095?OpenDocument
Please let me know if it resolves the issue.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 10 of 14
(3,988 Views)
