LV2011SP1 Build Error
I can confirm the problem is not limited to this project.  I opened another project which has "DAQmx 9.5 core runtime" as an added installer.  I built the installer successfully.  Then I selected the DAQmx Configuration Support installer and the build failed with the exact same error I posted recently.
If it helps, it looks like my windows 7 error prompt allowed me to cut and paste the whole issue, while Skydyvr's (winxp?) may not, or at least might not show that it's possible.  Is there a log file created on errors, or only if "create build log" is checked?
-Barrett
CLD
Message 11 of 24
(2,266 Views)
Just to clairify, I'm running WinXP 32-bit. I also have a Win7 64-bit machine, but have not upgraded to SP1 on that computer. I am about 80% sure I have built an installer using LV2011 (no SP) on the exact same program I'm having difficulity now.
Message 12 of 24
(2,261 Views)
To update the thread, I am investigating this and so far I have been unable to recreate the problem. However I am going to keep looking into it to see if I can find a way to recreate and debug it.
Thanks for all the details of what you have tried so far.
Message 13 of 24
(2,250 Views)
Then it is conceivable that we have received Platform 1 DVDs with bad sectors on them. Is there any way we can receive new DVDs that have been checked and verified good to replace our "bad" ones?
Message 14 of 24
(2,241 Views)
Running a repair install from the labview meta installer (in windows' add-remove programs panel) has fixed my issue.  I repaired LV2011, LV2010SP1 and DAQmx 9.5, but I suspect it was DAQmx that needed the repair.
-Barrett
CLD
Message 15 of 24
(2,234 Views)
Skydyvr - can you also try the repair install in the way that blawson described to see if that resolves the problem for you too? If it does not and you want a new LabVIEW Platform DVD, please contact your local sales rep for NI to see if they can send you that.
Message 16 of 24
(2,230 Views)
Still no-go. I tried repairing my DAQmx 9.3.5 and that did not work. I then went here: http://joule.ni.com/nidu/cds/view/p/id/2888 and upgraded to DAQmx 9.5. Just tried to rebuild installer and get the same error after it searches the platform 1 DVD again.
Message 17 of 24
(2,220 Views)
I might have been wrong about DAQmx being the one Smiley Wink  Try repairing LV, too.  If you go into your build spec you should be able to specify a log file for the build, and that could be useful.
-Barrett
CLD
Message 18 of 24
(2,216 Views)
True, but I can build it sucessfully if I don't include DAQmx. So to me that points to a mx problem - but what do I know.
How do I specify a log file for the build?
Message 19 of 24
(2,213 Views)
So when I went and looked for the file it said was missing and compared that folder to one on my other dev PC, there were 2 of 3 files missing in the folder.
Maybe this is a component that DAQmx triggers as a dependency but only gets installed/repaired by LabVIEW.
hmm, looks like a build log is an option for executables but not installers.  Can you select text in that error window?
-Barrett
CLD
Message 20 of 24
(2,209 Views)
