LV2017 "No debuggable applications or runtime libraries found"
I have tried to debug the compiled exe on LV2017 IDE, unfortunately in got the following message "No debuggable applications or runtime libraries found" and the Application or shared library ar greyed out. The same method working fine under LV2016. Is there any way to make this thing usable?
I am using the same settings in case of LV2016 builds.
(1,943 Views)
Accepted by topic author xGreaTx
Problem solved. The LV2017 SP1 has this bug. The executable name is greyed out (and cannot find by the IDE) if you running on the local machine. It's okay when you running on the remote target.
(1,874 Views)
