LV2OO Implementation
I am trying to implement LV2OO style global using the Visitor pattern example provided in this document.
Simulate_LV.vi shows the way I normally use LV2 globals. Simulate_LV2OO.vi is how I have used visitor pattern to implement the same functionality using visitor pattern.
I would like to know whether this is the correct implementation and if there a better way to do this?
Thanks.
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(3,961 Views)
Can you save it as 8.5?  I would like to see your implementation.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,923 Views)
LabVIEW 8.5 version attached.
(3,920 Views)
Very interesting.  I really want to use the LV2OO methods, but I'm still really having trouble understanding how they are easier or better.
To quote Stephen Mercer: "I am tired of writing LV2-style globals. These globals are great – very dataflow efficient, very easy to
understand. But you have to duplicate the VI every time you want to support a different data type. I figured
there had to be a better way. I’ve been thinking about this implementation for a while. It may not be optimal,
but I think it is an excellent starting point."
I understand his sentiments, but the LV2OO implementation looks a lot more complicated to me.  Just look at how many vi's had to be written.  The LV2 style is sooo much easier.
Would anyone like to comment?
(3,886 Views)
It is rather too big compared to a simple Get/Set LV2 Style. That's one of the reasons that prompted me to start this thread Smiley Happy
But if you have a complex multifunctional LV2 global, then I guess it will be wise to use LV2OO approach. I am yet to try out the performance implications of LV2OO method.
Anyway I've decided to use LV2OO so that I can understand LabVOOP concepts better.
(3,874 Views)
