LV7 Great Problems
since we updated to lv7, we have some problems.
1. Debugging dlls causes the debugger (ms vc6) to jump from one code-line to
another.
2. We have a lot of debug-messages like:"HEAP[LabVIEW.exe]: HEAP: Free Heap
block 1831d000 modified at 1831dc24 after it was freed "
I think the problem is, that we link against the msvctd.dll, labview uses
the msvcrt.dll, and so there a two instances of global objects and heaps.
Lv7 now uses 4 threads, lv6 used 1.
Any idea, what to do?
Christian Schmitz
(2,642 Views)
Christian,
Due to code changes and improvements, LV7 will allocate threads differently than LV6...this should actually be an improvement for your program.
Are you using LV created dlls? I don't understand how LV could be involved in a problem dealing with MSVC6.
Please tell me more about what you are doing with LV that returns the "heap" errors.
-Brett
(2,642 Views)
