LV7 hangs: opening VIs with matlab scripts
I am using Labview 7.0, and am having problems when trying to open certain VIs after
my computer crashed while Labview was open.  I am able to open most VIs, but cannot
open any VIs that contain Matlab scripts.   Labview hangs, and returns no errors.
I tried opening these same VIs on another computer, and they seemed to work fine.
Has anyone run into this problem before?  Should I reinstall Labview and Matlab?
(2,739 Views)
Hiii christine,
             Did you mean that the VIs with the MATLAB script are working fine in the other systems? because there is a default problem in the LabVIEW 7.0, there is a bug in the communication of LabVIEW with MATLAB in this verson of LV, this bug has been solved in the version 8 and after, so it could happen that thid could be a problem of this communication lack.
             Pls tell me if these vis are working fine in another system, and it could also be a problem of LV installation, it is possible that LV is not installed properly.
Hope this helps.
Reply me with the positive reply.Smiley WinkSmiley Very Happy
Nishant
(2,734 Views)
Hello Christine and Nishant,
          I agree that it would help to upgrade.  If that is not possible and the VIs won't open in LV 7.0 on one machine only, than I recommend repairing LabVIEW.  Please post one of the VIs that will not open on the LV 7.0 machine.
NathanT
(2,715 Views)
