LV7 to LV8 conversion problem
VIs converted to 8.0 compile ok and built .exes run correctly but when going to and from some sub vis, I occasionally see an annoying  vi title line flash on the screen.    What setting needs to be changed to block this (doesn't occur with LV7 version of same VI)?
Denis Kohl
Message 1 of 1
(2,428 Views)
